Hi all, We’ve just had double glazing fitted into our sash and case timber frames and I’m unsure if the job’s been done properly. The black spacer bar is very visible from inside (up to +1 cm into the glass in some parts) and the inside of the frame is unevenly cut form the inside, as if they lost control of the tools they used. We also saw they didn’t take out the frame to work on worktop but actually just free standing at the windows- which I assume results in less control when creating a gap for the new unit. The company now suggests covering the spacer bar with timber beads or wood filler, but both would be obvious from the outside. Is this normal for retrofitting double glazing into these windows, or does it sound like the glass wasn’t measured/fitted correctly? And is there a proper fix, or would we be looking at replacing the whole window for a decent finish? Appreciate any advice!
