There is an electric towel rail in my bathroom which I intend to replace by a new one when I refurbish the bathroom in due course. The towel rail is located in Zone 1 above the non-tap end of the bath (for the simple reason that is no room anywhere else in the small bathroom for it) so I shall be ensuring that I purchase one which is rated at least IPX4 if not IPX5 (I've found a couple so far).
The existing towel rail is controlled by a switched fused spur unit sited outside of the bath room (on the landing), so OK there. However the fly-lead from the t/rail goes into a 'flex outlet' plate in the wall in Zone 1, where it is connected to 2.5mm T&E which goes up through the partition wall to the outlet of the FSU. I get conflicting advice as to whether this is acceptable, or whether the flex output counts as a 'junction box' and therefore ought not to be in Zone 1.
If the latter, and the fly-lead supplied with the new rail is long enough, then I could simply run the lead through the hole in the flex outlet face-plate (and use the cable clamp to secure it) and run it all the way to the FSU, but in that case I'm not sure that I can find a new t/rail that has the fly-lead exit on the required side and a long enough lead.
Any thoughts please?
