OK, valve cover done!
Went went pretty well I think. Just slightly awkward getting it back on and wondering it is seated correctly.
I'm always paranoid about knocking some connection or damaging the ignition coil which is part of the valve cover.
The old gasket was not as bad as I expected, it was only slightly brittle in some areas, but it all came off in one piece and left no crap behind. But I could see where oil had been leaching past, it was worse in the areas of the engine that get hottest I think, near the spark plugs.
Everything looked in good condition to my untrained eye. No excessive old oil staining and the cams looked nice.
I assume it is best practice to let the new gasket bed in before turning over the engine. I just used the rubber gasket and did not apply any extra sealant. So I have no cure time as such, how long would you normally leave it before turning it over.
