Column rad not heating in all areas
5 Dec 2012
Just installed my new vertical column radiator, plumbed it in, turned CH on
It’s warming up but not on all vertical panels
I’ve released all air out of the system via the bleed valve (until water coming out)
It’s mainly the vertical column directly next to the inlet (TRV) side that’s cold
Edit: lock shield is turned to fully open position
Cheers
It's not really cold indoors yet - Is the room stat switching the heating off, before the entire radiator is warmed?
Only the upper part of my radiators, are getting luke warm at the moment, but getting warmer, as we progress to the cold weather.
Blast all the flow through this radiator by turning all the others off - just in case there is some sort of blockage or air lock. Then bleed again.
