EGGER Board
3 Oct 2025
This might not be the correct place to ask- sorry.
Has anyone used EGGER board but as the laminate roll. Apparently you can use it over certain boards and it’s cheaper than the proper EGGER board
It’s a normal high pressure laminate, from memory it’s supplied in post forming grade as standard.
I’m not sure what application you are using it in?
Generally laminate sheets are 3050 x 1220
I’m not sure it’s much cheaper than laminate worktop though.
You might struggle to find a supplier, Blackheath products are a major U.K. laminate supplier and I think they will sell to non account customers.
To glue it, use spray contact adhesive from toolstation / screwfix. Spray both surfaces, then while it’s still tacky, put a load of battens on the surface, about 10” apart, lay the laminate on carefully, line up the edges then remove one batten near the middle press down to get it stuck then remove another batten and repeat etc. Buy a karndean floor roller (about £25).
Make sure your timber sheet is over size as well as your laminate, then trim to size once stuck.
