- Joined
- 23 Oct 2025
- Messages
- 2
- Reaction score
- 0
- Country
Hi all,
Hopefully someone can help:
I've bought the Drayton Wiser multi-zone kit 1 (single channel) and need to wire the wireless receiver to a Vaillant Ecotec Plus 837 combi boiler.
The boiler is currently connected to a manual thermostat (Siemens RAA20) by a live and neutral. I assume these connect to 3 & 4 on the boiler, though I'm a little confused as the neutral is black and the live red at the stat end, but where it connects to the 230V on the boiler it's blue and brown? Is there potentially a connection in the middle?
From my research am I right in thinking I can just connect the wireless receiver from L/N/3/4 on the boiler to L/N/1 (common)/3(Heating on) on the receiver using a new heat resistant 4 core?
Can I leave the thermostat connection in place to use as an override and double up the wires connected to 3 & 4 on the boiler? (1 wire from stat and 1 from receiver on each). My concern here is that the two existing cables are using up the only two cable slots inside the power case, so I'm not sure where I would run a third cable while preserving the integrity of the case.
If I wanted to remove the manual thermostat what would be the process for making it safe, as the wiring runs through the house so no chance of pulling the cable out.
Thanks in advance!
Thanks in advance!
