In the case of a ring, the L+N+E begin at the consumer unit, MCB, go to every socket on the ring, then back to the same MCB. That's why it's called a ring, a full circle, out, and back. So their should be two reds (or browns), connected to the MCB. A basic check, to check that the ring has not been broken, is to take out those two wires, and check if there is continuity between them. You would also check the N and the E, for continuity.... No continuity, indicates a break in the ring somewhere.
