- Joined
- 31 Oct 2025
- Messages
- 10
- Reaction score
- 1
- Country
We recently had an extension raised to the first floor level. At the moment I have a gap between the floorboards of the original house and the caberdeck floor of the first floor extension where the doorway is. I have added a photo of what it looks like. The existing wall of the original house is what lies between the 2 floors so there are bricks and floor joists visible.
The issue I am having is trying to find a way to level this out so when the carpet is fitted later, it is level and feels like a flowing floor if that makes sense. Now on the original house side the floorboards range in height from the brickwork from 5mm up to 15mm in different areas across the doorway. On the new caberdeck side, the height ranges from 2mm to 9mm.
What would be the best way to bridge this gap and level out the floor. I was originally thinking about getting some plywood or similar and then using packers to lift the wood and level this off, but with the gaps ranging on either side, I'm not sure this will work.
