It (the screw shroud) should slide off unless its fixed wholesale with some kind of snap-in type fitting?Thanks for your advice, unfortunately i had no luck pulling it down or towards me. Felt like the chrome cover is stuck with the rail itself. I’m quite defeated
Can it pull off towards you then, if downwards doesn't work?Thanks for your advice, unfortunately i had no luck pulling it down or towards me. Felt like the chrome cover is stuck with the rail itself. I’m quite defeated
It must be important to try and tackle it at 4am. The u shaped cover should pop off. I’m one of the pics it has a slight gap, maybe try a bit or gentle prying.I didn’t install this shower rail, but thanks all for your help. Will update soon
How do you know he’s in Australia?Henry is based in Australia
Small wooden block. Placed on edge of shroud. Gentle taps downward with a hammer
Cool Bro. Thank you
