Replace a cooker switch
12 Aug 2014
Argyll
Hi there, thanks in advance for any advice.
I'm swapping my old stand alone oven, hob, grill with a new stand alone oven, hob, grill and installing an extractor fan above.
I have the usual above worktop cooker switch with the switched socket attached.
Obviously, I'll wire in the cooker to the existing under counter connection but what's the best way to connect the extractor?
Are you connecting the ovens to the cooker switch as well through Cooker Outlet Connectors?
If so, you can connect the hood via a Fused Connector Unit to any of the other connectors.
I like to have all the cooking appliances covered by the cooker switch but that's just me.
Thanks for the speedy replies and excuse my ignorance but do you mean I can just wire the extractor hood into the under counter connection alongside the cooker?
Hi there, thanks for the advice but I've probably not been clear. I'm replacing a stand alone cooker with a new stand alone cooker. Can I just wire the extractor into the same under counter connection controlled by the same above counter switch?
So, I should take a cable from the under counter cooker connection and install a fused spur unit with a switch above the counter to control the extractor?
Yes - you can put it up by the hood if you want.
Concealed cable must run only vertically or horizontally from the connector and switch.
