I'm hoping someone can help me to work this one out. The situation is that there is a 3-way splitter plugged into the BT main box, of which only two sockets are currently in use: one for an answerphone, and the other for the broadband filter, into which are connected the router and the actual traditional landline phone. The person concerned is housebound, and therefore does need to have a properly functioning landline.
For the past couple of weeks, there has been a problem on the landline in that you can't hear the caller, but they can hear you! So you pick up the phone, speak (you hope) to the (inaudible) caller and explain the situation, and maybe ask them to leave a message on the answerphone if necessary so someone can ring them back on a mobile. Usually when you pick up the receiver either to make a call or to receive one, you get nothing but dead air, although occasionally there is an attempt at something approaching a dialling tone - the odd beep or two. We've plugged an old spare phone into the broadband filter instead and that works all right, but it is terribly basic, and doesn't have any features such as caller display, stored phone numbers etc. You can in fact still dial out from the main phone, it's just that you can't hear anything whatsoever at the other end.
(Co?)incidentally, there were some people from BT OpenReach working on the line out in the road a few days before the problem was noticed. We've been in touch with the service provider and they've tested the line and thought the line was okay. So what I'm really trying to work out is to what extent the problem is on the outside line and to what extent it's with the phone and/or connections. There's been no problem until the last few weeks.
Do REN numbers still matter these days? As I say, we have the phone, answerphone and router plugged into the main box. Phones and answerphone are REN 1, but I'm not sure about the router. I was thinking we could plug the spare phone into the spare splitter socket as a temporary measure to enable the caller to be heard, but I don't want to overload the socket - if such a thing is still possible, anyway.
I've replaced the broadband filter without it making any difference. Haven't tried replacing the splitter yet. I'm wondering whether it would be worth trying replacing either the curly cord from the receiver or the cable between the phone and the broadband filter - I can't cannibalise the old phone as it's so old that the parts can't be separated. I suppose it's also possible that it might be the receiver at fault - but then I'd need to find a suitably-shaped replacement so that it fitted the base properly.
Would appreciate any thoughts from someone more familiar with telecoms than me - thanks!
