- Joined
- 18 Aug 2025
- Messages
- 63
- Reaction score
- 1
- Country
Hi again guys so just some advice again
got a old 60a supply coming into the property looking at getting dno involved to move the meter from the internal wall to external cupboard and would look to upgrade to 100a from 60a
i presume it would be the dno that moves the mains incoming cable into the new box would they also move the meter and upgrade the fuse or would this then fall to the supplier ?
also once the new meter and fuse was in the box , at the moment the fuse board is right next to it but when its moved to outside we want the the board moved around 10 meters away from the meter what mm cable would be used for this ?
In the run from the 100a isolater to the 100a rcd in the consumer
many thanks again
many thanks again
