As often discussed, although most mains-powered smoke/heat etc. alarms give an indication of power failure, I personally favour running them off a downstairs lighting circuit (rather than a 'dedicated' circuit) so that failure of the circuit concerned is rapidly noticed.
As also often discussed, it's generally considered undesirable that alarms be fed through a switch or FCU, since the alarms are then too easily 'disabled', deliberately or even 'by accident'.
However, since there's something to be said for being able to 'isolate' the alarms (to work on them) without losing lighting, what do people think about feeding them through a key-operated switch or suchlike? That would certainly prevent accidental operation, and would do at least something to deter deliberate operation.
