Hot water Vs cold water feed for dishwashers?
24 Jul 2023
Just wondered if one is better than the other.
We've narrowed it down to 2 dishwashers and one - the Kenwood one wants cold and a hisense one wants hot water feed apparently. The two companies claim there's good reason for this but I suspect there might be a drawback somewhere?
At least 80% of them use cold water feed in the UK... they use such a small amount of water its not worth using your hot water, and having part of it sitting in your pipes from the boiler/cylinder, wasted
If you look carefully you will see very clearly that one says hot and the other days cold. And I definitely didn't edit it because I wrote cold twice .
Except your post shows it was edited .Dishwasher does not need hot water feed to rinse so waste of time buying one , it also needs specific temp for different wash types which may mean the incoming water may be too hot leading to longer wash time as it waits for water to cool.
My Miele is hot feed (though obviously still has a heater if you want to connect to cold). It's full of all sorts of fancy stuff and I believe it does things like extracts any excess heat from the water to use in the drying cycle etc. We have an unvented cylinder with a direct pipe to the dishwasher so it actually gets hot water not cold like a combi while it ramps up.
I did try to monitor electricity consumption as the machine can be set to display it in kw but it only shows full kw so not sufficiently accurate.
I can see no reason the makers would want to make their products use more energy (and sell less replacement heater elements).
