Carpeting a floor - front door catching the carpet.
14 Feb 2003
Hello all
I'm looking for a bit of advice on floor coverings for a hall space, please see my attached image, it is quite a small space approx 5.2m2
The exit door in red, is UPVC in a UPVC frame, I cannot see any way to adjust the height of the door.
The floor is black bitumen?? covered concrete. With the previous covering of 10mm underlay and medium thickness carpet, the door would catch quite badly on the carpet from about 1/2 open.
I am looking for a solution to the door cathing on the carpet issue.
Because it's a concrete floor I'm keen to have underlay of some sort to help keep the heat in.
I can see two possible solutions:
Drill a couple of exporatory holes to find out how thick the bitumens is, if it is around 10mm or more, see about removing the bitumen; this would "lower" the floor by 10mm or so and felt/wool underlay would be better than the bitumen for insulation. How easy is it to get the bitumen off the concrete floor?
Have part of the floor covered with an enty way type of carpet with no or thin underlay where the door sweeps over it, and the rest of the floor with thick underlay and carpet.
The transition between the two would be the problem, from what I can find, transition strips for different heights seem to be for tiles/laminate to carpet. I've been struggling to find a transition for carpet to carpet with different heights, the only likely ones I've found are "Z" bar types - am I right in thinking the Z bar allows me to "tap" the bar down with a mallet (with it bending on Z section) so it sits on the carpet on both sides and covers both heights?
Maybe use a cork underlay , from 2mm thick.
Thanks for this - I'd never thought of cork.
I might be a good idea but everywhere I look the thermal properties of cork are listed as 0.038m2K/W which is meaningless to me.
If possible, if you know, please can you advise roughly - 4mm cork is as good at insulating as 8/10/12/15 mm foam/felt? just as a rough idea so I know what to expect?
It is slightly more efficient than foam per mm but you can only fit what you have room for .Your carpet provides most of the insulation .
I've added a pic as an attachment - thanks.
Not 100% but if you can prise off end plate you may be able to do some adjustments. My thought is if you can move the door out at the bottom and middle hinges it may swing the bottom leading edge of the door more upwards when opening and not catch the carpet. Not certain on that but perhaps worth a try before you start digging things up??
This is exactly the kind of comparison I was looking for - very helpful. Thanks very much.
OK thanks - I'll examine the hinges later this week when I get an opportunity and see what the options are.
I'll report back with progress (or lack thereof).
Right I'm back, sorry for the delay, I've had a lot on.
The hinges look like they have a small amount of adjustment, as you mentioned I could used this to "tilt" the door slightly, the idea was to lift the corner of the door away from the floor when it swings out.
Extra checking reveals the door is rubbing not on the corner but around the centre of the bottom when 1/3 open onwards, I think there must be a raised area on the floor.
Using the adjustment to lift the door over this bit, will need a more adjustment since it is in the centre not the corner, I'm not sure if there is enough in the adjusters to do this and if there is I think I run the risk of the door looking lopsided and perhaps not shutting/latching properly as well, so I don't think this is a solution.
My new idea is - since it looks like a 'lump' in the bitumen, can I "shave" it down with something? Perhaps an electric plane, which would probably need new blades afterwards....
Don’t try to shave the bitumen, in my experience it can be quite brittle.
Do you have a doormat? If I were you, I’d consider cutting the carpet back from the door with an aluminium trim edge, and fitting a large coir doormat directly onto the bitumen.
I like the electric planer idea which is similar to what I did when I needed to humps/ridges in some floorboards before I laid some lino. The drier/brittle the bitumen the better as it would be more akin to wood. Try taking of 1/2 mm at a time and see what happens, if it works, fine, if not then plan C whatever that may be?
Thanks for your idea - I had to look up coir doormat, this was an idea I already had (except not the coconut matting, which I like)
It still has my original issue of the transition strip between the doormat space with no underlay and the carpeted space with underlay - the transition strip needs to be two different heights and all the strips I find for different heights seem to be for tile/laminate to carpet.
You just use a Z-shaped strip which folds down to hold both sides of the transition, with a slight slope in the finished level of it
Hello, sorry for the delay, I've been away.
This sounds like the right solution - are the Z strips made so they can be "tapped" down with a mallet so they meet both side with a slight slope?
