Saying that it was in a tree and there are lots of squirrels. I dunno
Was there a squirrel, on the ground, below it, with its legs pointing skywards?
Every time I speak to them I suggest that they really ought to do something about 'protection' of the cable, but, a few years down the road, they do not seem to be listening
no plugs - ends of cable disappears into things that would probably need a tin-opener to get intoAssuming you cannot disturb the plugs, on the ends
I could, or all sorts of other things like that - but why should I do their work for them (and, of course, they might complain that I had been 'interfering with their equipment'!)- Could you not wind some of that metal spiral, from an old shower hose, around it?
Wire strippers.Thecwires are so thin. How do you strip the insulation off?
I have to say that's what I still mainly use, and it does the job.
That's exactly what I've done. However, even when one tightens the locknut "really hard", the damned things eventually come loose!Buy several pairs, set each one to a common size, tighten the locknut down really hard, label the handles, no more fiddling.
I've got some cheap ones of these but sometimes they cut instead of strip:
Maybe. I recently snapped off one of the adjusting screws by trying to tighten the locknut 'really hard' (with a tool)Loctite?
Wire strippers.
This style is a bit fiddly but works:
Why do you talk to the squirrels John?As an aside, I've been trying for ages to talk some sense into Calor. On top of my LPG tank there is a sensor (detecting how full the tank is) and a telemetry module, which sends the information to Calor so that they know when the tank needs topping up, and those two things are joined by about a foot of thin flexible PVC-sheathed cable.
Every month or three, that cable gets severed (with teeth marks) and so I have to get Calor to come out and replace it (certainly more than once per year). They acknowledge that this is a very common problem, nearly always due to squirrels, and my garden is certainly well stocked with squirrels. Every time I speak to them I suggest that they really ought to do something about 'protection' of the cable, but, a few years down the road, they do not seem to be listening
But you seem to have so much spare time to delve into the navel fluff of anything electrical on DIYnot..I could, or all sorts of other things like that - but why should I do their work for them
Why do you talk to the squirrels John?![]()
In reality, I have far less 'spare time' than you would think - although I admit that I'd have a lot more if I didn't participate in this forumBut you seem to have so much spare time to delve into the navel fluff of anything electrical on DIYnot..
That's very probably true - and, as I wrote, there are umpteen things I could do to protect the cable. However, as I also wrote, one of the main reasons I haven't done anything myself is that (on the basis of past experiences), I suspect that, if I did, there might well then be all sorts of hassle resulting from the fact that I had 'interfered with their equipment'. They are understandably concerned about anything which might impact on 'gas safety', but don't seem to have the sense to understand that 'interference' with that cable would/could not have any 'safety implications'.And I bet you could coil a bit of shower hose on in less time than it takes to listen to calor's hold music in just a single one of these phone calls you have to make to get them to come out and replace your cable..
