Best way go link electric cables outside
22 Nov 2018
Wanna run two or three cables from my flat to some hedges 30 or 40 metres away. Shall I run the two orange 15 metre cables joined in the grey boxes then connect the lights to a standard multi socket
Howzabout the yellow reel?
Yellow reel- IP54 rated
Orange reel dunno Ip rating
Grey box IP54
with
Oh, no sorry I thought you was gonna cut the hedge :) wrong time of year for that.
Is for something temporary, or will it be there all year round and beyond?
Xmas lights?
Waterproof IP68 is costly, in the main we go water resistance, which could be simply a plastic box over the plug and socket, done that to charge car when one extension lead not long enough, was only connected overnight, plug and socket on a brick, so surface water could not reach it, and the back of house should not have any visitors, although I do know a parcel was once left at back of house, but no real reason why anyone should visit rear of house without invitation.
Front of house a little different, postman, milkman, carol singers, trick or treat, all likely to visit front of house, so any electrical leads need to be where kids messing around are unlikely to come to harm.
If I needed to charge the car battery on the road, then even more care required, and if to be left connected for an extended time also more care required, I look at the power outlet found on a typical caravan site as being the minimum required when the general public including children can access the plugs, sockets, and connecting cables, using a pair of these
to join cables without some further protection like being kept off the ground, and covered from direct rain, is not really good enough, but one of these
in the side of the caravan so feed cable not on the floor, and RCD protected, then no real problem.
Someone cut the wire on the cables to my Christmas lights- best way to connect them back?
Were they cut or is it foxes/squirrels?
Deliberately. I probably left them on too late and the flat next to them got angry. It's a Communal garden. Saying that it was in a tree and there are lots of squirrels. I dunno
As an aside, I've been trying for ages to talk some sense into Calor. On top of my LPG tank there is a sensor (detecting how full the tank is) and a telemetry module, which sends the information to Calor so that they know when the tank needs topping up, and those two things are joined by about a foot of thin flexible PVC-sheathed cable.
Every month or three, that cable gets severed (with teeth marks :-) ) and so I have to get Calor to come out and replace it (certainly more than once per year). They acknowledge that this is a very common problem, nearly always due to squirrels, and my garden is certainly well stocked with squirrels. Every time I speak to them I suggest that they really ought to do something about 'protection' of the cable, but, a few years down the road, they do not seem to be listening :-)
