Hello,
I'm converting my switches to smart switches and have run into an issue with a 2 gang 2 way switch. I removed all wiring and then realised it's not so simple. Attached picture is from another post but similar to mine.
Downstairs switch is 2 gang with 1 controlling downstairs light and 1 the upstairs light in 2 way mode. Upstairs has 1 switch working 2 way to control the upstairs light.
What I want to do is remove the upstairs switch all together. Put a 2 gang 1 way smart switch downstairs (which has only 1 com and I'm OK to have both lights on same mcb). So I think it's the slave switch of the 2 way circuit I want to keep to control the upstairs light. The downstairs switch has its own COM for the downstairs light.
I connected the smart switch and the downstairs light works fine. But connecting the switched live of upstairs light and turning on causes the mcb to trip. I kept the permanent live coming from upstairs in a choc block and the COM of downstairs light in the Lin terminal of the smart switch.
Can someone help please to make this work?
