Wiring a Fan
20 Dec 2025
I have a new Vent Axia bathroom fan type VA100XT to replace the old (same model number) but the new version has live, neutral & LS terminals. The cable coming from the pull cord switch is standard live, neutral and earth. Does anyone know how to do the connection?
Cheers Bob
Sounds like you have a different model number as the existing sounds like it’s just on and off. Can you provide a photo of the existing wiring?
Country Fan - they are the same model although it has been upgraded over the years - The old model ref is 251410A and the new is 251410C.
Andy PRK - Do I do the loop from the live to the LS directly in the fan - not wanting to do anything stupid with electricity.
The OP's wiring does not have a permanent live.
Both L and LS must have power when switched on otherwise the fan won't run at all.
Not sure about it.
Recently I fitted a fan in exactly the same situation and connected the switch live to the LS leaving the permanent live connection (L) empty.
The fan runs when light is on and stops immediately when off.
Isn't the permanent live just for the overrun by timer?
Not sure about it.
The permanent live IS required for the overrun timer function to operate, the switched live is to enable it.
You have the permanent live connected to the L input - this provides the power to run the fan.
The LS input is the switched live which is just to tell the timer function that on the switched live has been removed, the permanent live is still to be used to power the fan for the duration of the timer - the power to run the fan is not taken from this terminal.
If your fan runs just using the LS terminal then something weird is going on there, is it actually a timer fan & if so what make/model?
That is how I'd expect it to be...
but I believe I've seen a similar statement to Johnys' before so I wonder if some makes have a slightly different arrangement?
You've put doubts in my mind now.
Fan had a timer function but wires in the ceiling were LS, N, E.
I followed the instructions and I was sure that I connected the LS to the LS, but I'm not so sure now.
Maybe I connected it to the fan permanent live slot and left the LS slot empty.
Surely I didn't bridge the L and LS.
IIRC, the fan is an Xpelair bog standard with timer (Screwfix didn't have the non timer in stock apparently).
