Shower restyled hall ceiling
28 Dec 2007
Worcestershire
About 9-10 months ago we noticed a tiny mark on the hall ceiling more or less underneath the shower upstairs. It was minor and appeared to be a line where the ceiling boards joined. I couldn't see any problems, and although I couldn't see any gaps, I redid the silicon sealing around the shower tray upstairs, very untidily but it looked well sealed.
About 6 months months later, I came home to find water pouring through the hall ceiling after my wife had used the shower. Still puzzled where the water was getting through, I called a plumber and he pointed out that the tile grouting around the shower alcove walls was worn and porous in places and showering had caused water to gradually seep through to build up on the ceiling below causing the final 'cascade.' This must have been building up a long period, possibly years. He said the shower needed retiling which was not covered by the insurance cover under which I had called him out. He said that the shower tiles should have been periodically resealed possibly every 18 months. I am now faced with the cost of having the shower retiled (£1700) and finding a way to repair or patch the ceiling below.
A lesson learned the hard way ! The house was built in 1983 and the ceiling is what I believe is called Artex finish. Knowing the possible risks with Artex, I am trying to think of a safe and easy way to diy patch the ceiling rather than have the whole ceiling renewed which would be very disruptive in the hallway apart from the cost. Photos attached. The circular 'drop' is about 12 inches diameter and seems to be paper thin. A thin patch could be disguised, I thought, by using thick 'sealant' type paint with say, wood shavings mixed in to simulate the rough artex finish.
Any ideas appreciated
Comments on the need to 'reseal' grout are also welcome.
Easy to cover damage, scrap off damaged area and recoat with artex using a stipples roller .
Thanks, that's very encouraging. I'm assuming the boarding behind hasn't dropped. Is 'Artex' still available? I was told it contained asbestos, at least at the time our house was built.
Good question. Can't be 100pc sure but no sign of leaks from the waste under the tray and the supply pipework is in the airing cupboard next door (it's an exposed bar mixer shower) and looks fine. Original Plumber said grouting was crumbling and chap that is retiling the shower agreed that after 42 years it's to be expected.
Hmm, seems a little short sighted to spend £1700 on re-tiling the cubicle without checking/redoing the plumbing just to be sure.
A wild idea... Could you poke the straw, from something like a carpet adhesive, through the hole in that loose patch, spray all round, then push it back into place? Maybe put a cushion, in a plastic bag, with a bit of board under it then propped on some timber, until the glue sets.
Could the existing tiles, assuming they are firm, simply have the grout cleaned out, and be regrouted?
That's an excellent idea, I was trying to think of something like that. I even bought some 'No More Nails' glue but couldn't think how to apply it or how to support it.
Some of the tiles have hairline cracks and some worse where there is a fixing like the shower valve supply pipes and the riser rail. Probably overtightened. How the others got cracked is a mystery as I we don't swing anything about in the shower !
Can you recommend what would be the best type of glue?
The PB, itself will need to be firm and thoroughly dry, and remain dry in the future, even if it means botching the tiles somehow, to prevent any further escape of water - maybe tape plastic sheet over the tiles, to keep them dry, and direct the water to the drain. At least until it can be retiled.
My own bathroom shower tiles were installed by me 40+ years ago, have not received any maintenance at all. So why yours needed work every 18 months, beats me?
