I don't mind a ring final circuit but diyers dont know how to add to them properly....anyone (ish) can add to a radial circuit
Indeed - but if one was only installing 32A Method C radials, one would only need to buy 4mm² cable. As I've said before, if the only possible installation methods would require 6mm for a radial, I probably would revert to a ring, since (unlike 4mm²), 6mm² T+E is not so easy to use with (and a problem to get three dictators into a terminal for branches).Well, its obvious. If you want to plug the same load into the sockets. (for example a kitchen). Then a radial will either need to be 4 or 6mm .... And as an the op is more of a DIYer, its a bit silly to have to buy one real of 4mm when you can use 2.5mm on a ring.
It obviously depends upon the topology of the circuit, but the cable for a 4mm² radial will often cost much the same as, and sometimes less than, that for a 2.5mm² ring. Current TLC prices (excluding VAT) are £40 for a 50m reel of 2.5mm and £35.25 for a 25m reel of 4mm. Hence, in the simplest hypothetical case of sockets arranged in a straight line radiating from the CU, with the furthest socket 25m from CU, it would cost about 13% more (in cable) to have a 2.5mm² ring than a 4mm² radial.I'm sure you investigated 4mm prices in the past, and they weren't good value either, as not a common use
Good question - but maybe almost moot - since, as I've just written, using 4mm² (radials) is not necessarily 'dearer'.So people don't use 4mm² because it is dearer because people don't use it. How could that be overcome?
A valid point - but I'm not convinced that DIYers with the degree of knowledge you're talking about would necessarily always use the correct size cable when 'adding to' a 32A radial!I don't mind a ring final circuit but diyers dont know how to add to them properly....anyone (ish) can add to a radial circuit
Yeah I think 2.5mm takes 32 amp easy, don't tell anyone I said that.A valid point - but I'm not convinced that DIYers with the degree of knowledge you're talking about would necessarily always use the correct size cable when 'adding to' a 32A radial!
There is a 'saving grace', although I suppose I shouldn't mention it - since it flies flagrantly in the face of the regs! .... I would suggest that the reality is that it is exceedingly unlikley that a domestic 32A radial wired (in part or all) with 2.5mm² would ever result in any problems - given that it would be very rare that such a circuit would ever be asked to carry more than 27A (or, probably, more than 20A or so) in total for appreciable periods of time!
I won'tYeah I think 2.5mm takes 32 amp easy, don't tell anyone I said that.
We're obviously talking about 25m (or whatever) 'as the cable flies', which (even in a 'normal/modern' house) can sometimes equate to a much shorter distance from the distance 'as the moth (or even human) flies' (see **) - but I'm pleased to see you saying that, and I hope you might remind people of it next time eric start talking about 'maximum circuit lengths' of 106m (or even 32m)If the furthest socket is 25m away for the CU then I think that is a big old house rather than a normal/modern house.
If you also promise not to tell anyone I said this .... in the context of a domestic 32A radial, I might possibly even have said something similar about 1.5mm² (and maybe even 1.0mm²) cable, for the same reasonsYeah I think 2.5mm takes 32 amp easy, don't tell anyone I said that.
