seems like a good time to replace the boiler
Yeah, that was definitely an option. Hard to weigh up the cost of a new one vs efficiency gains though. The hot water tank was in a different location in the property, but I've moved it, so it's next to the boiler, which will hopefully help when it does come to replacing the boiler. I think the main bit of lost effort will be in connecting up the header tanks, but I don't think that's too bad. I also don't have mains gas where I am, so when it does come to getting a new boiler, I'll have to decide on whether to stick with oil, or swap my tank out for a gas one (or pay the ~£60k (nope) to get a line run to my property)...
a pressurised system boiler that supports PDHW
I hadn't heard of PDHW to be honest, so will definitely look into it when the time comes. I had just assumed that I'd be looking at a combi boiler really; I like the idea of no hot water tank!!
Cold feed on the boiler return is the old way, up till about 1970. Trouble with it is it causes seewsawing between the fill and vent on pump start/stop
That is interesting, the property was built mid 90s and the boiler was made in '94, so not sure why they did it this way then...
I've been trying to move things about today as per denso13's advice, but it's looking like it's going to have a lot of knock on effects that I'd rather not contend with, which is really annoying. I think I'm going to leave it as it is and if I end up with problems, I'll try a combined 22mm vent and feed. Hopefully I don't get problems though, as this was how it was connected up before I moved things around, but who knows, pipes have moved around, so maybe that'll change things...
