I've a working system at 2 bar but a single column radiator which will not heat up unless all other radiators are heavily restricted. By restricted I mean so much the boiler cycles the heat due to minimal flow and the other radiators don't get hot. Obviously this points to blockage between the flow/return pipe, valves or the radiator itself.
The radiator is brand new one of these common models - https://www.ebay.co.uk/itm/391972553871
There is (or was no air in the radiator at all). I've now disconnected the radiator and the water has came out both ends easily. It's clean as the system has had several flushes with various radiator changes over the past 6 months. Then I opened the values expecting one would have low pressure and water has came out fine of both!
The inlet heat I'm pretty sure was connected to the left side which is correct I believe for these radiators although others say it doesn't matter. The valves are basic non TRV ones so it wasn't them either. The 15mm copper is only about 6M in total not really enough to be too long to act as a restriction I think, plus I have another which is almost an identical length and same radiator and it doesn't have the issue at all - red hot!
Any ideas as I'm now out of them!
