- Joined
- 29 Dec 2025
- Messages
- 4,302
- Reaction score
- 224
- Country
For background see the similar headed posts in Builder's forum:
I want to prevent unauthorised use and theft. I can prevent theft, when it's in the closed position because access to any fixing bolts is prevented.
I want to prevent unauthorised use, and lifting of the table, to prevent access to the fixing bolts.
I've ordered some panel mounted and cable mounted plugs and sockets from RS Components, so that I can detach the mains cable and the operating cable. I'll remember to mount the socket on the live side of the plug/socket connection. The two pairs are of different types to avoid confusion or incorrect connection.
Unfortunately the existing electric operation is foot pedal operated, To raise the table, one presses one pedal which turns a rod, which moves a lever to close a microswitch, or not so micro, as it happens.
To lower the table one presses a different foot pedal which is totally manual, and turns the release valve on the body of the jack.
I have ordered a three wire C20 type plug and socket for the control. It only needs two wires.
But I'm having difficulty finding a simple 'press for on', 'release for off' cable mounted control, rather like a bell push, but hand-held.
Obviously it needs to be mains voltage, for about 10 amps (initial start-up) of the ¼ horsepower motor.
I've seen radio controlled hand-held devices but they're all low voltage fed, and I'm unfamiliar with such equipment.
So I've ordered a hand-held enclosure, from RS Components ( Rose 2921 Yellow Polyamide Handheld Enclosure, 85 x 85 x 221mm) in which I'll mount a simple one way switch - on to raise manually, switch off at the correct height. The motor would keep running when the lift is at maximum height, without any apparent harm. There are safety locks to prevent any accidental lowering.
I'll remove the manual operating pedals in such a way that I can replace them in the event of necessity.
In hindsight, and in a slightly different scenario (ownership of the frontage) I would have ordered the in-ground model, as used in motorbike dealers.
It would have been easier to make it theft-proof, and to control. However I don't know if there's any manual operation to lift the table with the in-ground version.
It would certainly have been a cleaner, tidier provision. As it stands, if it's not needed in the long-term I can easily remove it with little visible evidence of its existence.
Any advice or comments gratefully received.
Disabled access to Holiday Home abroad
I've finally taken delivery of my motorbike lift table. It's electric and manual.I want to prevent unauthorised use and theft. I can prevent theft, when it's in the closed position because access to any fixing bolts is prevented.
