Bus driver sacked OMG
What is a common law? Make some sense.
law established through decided cases and custom, rather than specified in statute. The statute in question specifically states the common law rights are replaced. That is because at the time, common law had not established the right to strike first in self defence, making it difficult to use force to stop a crime.
it is a common law
whereas:
is statute
And? It is just a meaningless statement
This however...
Here is a reminder of why you shouldn't pursue someone with a weapon, after a threat has passed........
The Criminal Law Act 1967 does not give you a blanket right to chase a fleeing suspect with a weapon. While Section 3 of the Act allows for the use of "reasonable force" to prevent crime or make a lawful arrest, using a weapon against a fleeing person is extremely likely to be deemed disproportionate, excessive, and illegal.
The Legal Position (Criminal Law Act 1967)
  • Reasonable Force Only: Section 3(1) states: "A person may use such force as is reasonable in the circumstances in the prevention of crime, or in effecting or assisting in the lawful arrest of offenders or suspected offenders...".
  • Proportionality is Key: The force used must match the threat. If a suspect is running away, they are generally not an immediate threat to you or others. Chasing them with a weapon implies a desire to harm or punish (revenge), rather than to stop a crime.
  • Grossly Disproportionate Force: If you chase a suspect and use a weapon—especially if you cause serious injury—it will almost certainly be considered "grossly disproportionate," and you may face criminal charges, including wounding or assault, regardless of the fact that they stole from you.
What if I chase them as they run off?
This situation is different as you are no longer acting in self-defence and so the same degree of force may not be reasonable. However, you are still allowed to use reasonable force to recover your property and make a citizen's arrest. You should consider your own safety and, for example, whether the police have been called. A rugby tackle or a single blow would probably be reasonable. Acting out of malice and revenge with the intent of inflicting punishment through injury or death would not.
Chasing a fleeing suspect with a weapon and subsequently using it is highly likely to be considered malice, revenge, or retaliation rather than self-defence in legal terms, particularly if the initial threat has passed.
(Source - CPS)
Waffling again. Reasonable force rules are defined and applied across the board, common law statute or otherwise...
Reasonable force' guidance has been tested against and applies to:
Criminal Law Act 1967 (Section 3)*
Common Law
Children Act 1989 & 2004
Education and Inspections Act 2006 (Section 93)
Use of Reasonable Force in Schools – DfE Guidance
Mental Capacity Act 2005 (Sections 5–6)
Human Rights Act 1998
Health and Safety at Work etc. Act 1974
Equality Act 2010
YOU quoted the CLA 1967. Have you changed your mind on that now?
Not entirely, the credibility of the account given by the accused carries a fair degree of weight.
The injuries received and any other recorded or witnessed or physical evidence is also taken into account.
An accused can't simply say, "he came at me first".
Of course. That goes without saying.
A jury in a criminal trial would have to decide whether the 'honest belief' was genuinely held.
But once the jury has established that the 'honest belief' is genuinely held, they use that as the basis for determining whether the force was reasonable. Even if the defendant was mistaken in his honest belief
Common Law
Equality Act 2010
Are you suggesting the same rules for reasonable force are applied? yes or no. This seems to have been your argument thus far.
It remains a fact that your rights to stop a crime/criminal are defined in sec 3 as I have been saying all along, rather than the common law right to use reasonable force to defend yourself, which is the "wrong law."
And they would use other evidence and actions leading up to the incident, such as retrieving the stolen property then letting the thief go, or the potential thief legging it without the stolen property, and the CCTV evidence to assess the credibility of the accused's version.
I am only trying to explain the legal principles involved.
I haven't really tried to apply them to this particular case.
I’m assuming the cctv is not public or have people seen it?
