The bit between worktop and wall - in a kitchen
5 Dec 2013
Midlothian
I am looking to replace a worktop in a kitchen. There will be a sink in the worktop. Washing machine and dishwasher underneath so a little bit of heat. No cooker or oven involved they are on a different wall.
The existing worktop is 61cm deep. I have found a suitable worktop but it is only 60cm deep. Due to a reason too hard to explain I need to fit the new worktop with the front at the same distance from the wall as the old worktop, which will leave a gap at the back of the worktop of 1cm between the wall and the worktop. I can pack it out a bit to keep the worktop rigid. But I still have the problem of having to seal up the area between the wall and the worktop to prevent spillage.
My question is: would it be a big mistake to use the following product fixed in place with silicon or acrylic adhesive?
Thank you all.
Not so easy to find a matching worktop at the right price. Plus it is a long cut to do without proper tools. I will be buying a jigsaw and downcut blades to do the sink cut-out.
I have to put something between the wall and the worktop anyway. I can also get quarter round quadrant 17mm deep which would probably do the job. What normally goes there? The quadrant is meant to be for that kind of thing, isn't it?
Not actually made for that use, no, it is intended for UPVC door/window fitters, but yes, it works just as well indoors. It's not self-adhesive, and so needs something suitable, to stick it in place - and will solve your problem for not much cost.
Add a matching upstand usually around 12mm - 18mmthick .
Too expensive. Plus there are tiles on the wall with pictures of bowls of fruit which would be cut in half because the upstand goes higher up the wall.
I did an in-situ sink cutout with a regular fine wood jigsaw blade. What do others think? There are disadvantages to downcut blades, which is why they are not the default.
Remember that the edge of the sink overlaps the worktop by ... maybe 15mm? So small chips are not visible.
You can experiment with some cuts in the middle of the sink area first.
I've done worktops for both offspring as well as a couple of rentals and at least 2 iterations of home,
Son's was worst as he wanted a Belfast sink so no lip to hide roughness. My approach is drill the corners to give a nice radius then bulk of cuts using circular saw. Mine (Evolution) doesn't have a riving knife so easy to plunge especially if you take the time to set decent guiderails in place. I'm sure a tracksaw would be easier but you use what you have. Decent blade, go nice and gently and finish cuts with a fine tooth hand saw. Strip of masking tape along the cut.
Thank you. I already have jigsaw with the old type of blade fitting (u-fitting) but would maybe buy a better saw to get a better selection of blades.
I seem to recall job and knock saying the up cut blades deviate on the underside. I have never used one. I tend to use my track saw and then a jigsaw or japanese saw for the corners.
I think the other problem with upcut blades is that you need to prevent the jigsaw bouncing up. Probably less of an issue when using a better quality saw such as Festool ot Mafele
You can use downcut blades with a jigsaw but you need to turn the oscillating function off. Expect to use two jigsaw blades on a sink cutout they blunt quickly Dewalt T101BR seem to hold there sharpness for longer, dont buy the Reisser version.
Howdens do a 616mm worktop which you can cut 6mm off with a downcut blade, granted it'll take ages, but its better than a 10mm gap.
Can you fit the worktop, then put a sheet of plasterboard on the wall above it ?
If not, a competent tiler would get most half decent tiles ( not chamfered) to bridge a 1cm gap, including a silicone bead along the join to worktop. (Usually done by bridging the gap with the cardboard off the tile boxes, to ‘sit’ a (8mm ) tile on, + 2or 3 mm adhesive ). :-)
