I need to change a hot water tap without an isolator.
I have a vented hot water system and my tank cupboard has 3 pipes running through it from floor to ceiling. One carries hot water and is connected to the top of the tank, the other 2 carry cold water - one has a label "isolation valve" it also feeds my electric shower. The other one has a label "stop valve".
My main cold water stop cock is downstairs and there are 2 cold water tanks in the loft, presumably each fed by one of those 2 pipes .
The hot tank has 4 pipes connected to it
1) the one i mentioned above
2) one labeled cylinder drain
3) one entering in the middle of the tank that comes from my boiler via a 3 way valve
4) one at the base of the tank with an unlabelled red tap on it that doesn't seem to change anything albeit it does clearly open & close with about 10 turns
Given my lack of isolator on the hot tap in question, am I likely to be able to change it without draining the entire hot tank?
