Is it worth altering the water temperature dial spring/autumn to winter?
27 Jan 2008
Llanfair Caereinion, Nr Welshpool
I have read about weather compensation, and it seems it alters the circulating water temperature, which I can see helps with a modern boiler. But what about with a non condensing, non modulating boiler? There is a large dial on the front to adjust the circulating water temperature, why?
I see that the hotter the circulating water, the faster a room will heat up, so the latter a temperature change can be left, so if a room is allowed to cool to 16°C overnight and is wanted to be at 20°C during the day, and 22°C in the evening, the hotter the water, the latter the change can be made, so with no hysteresis the hotter the water the better.
But there will be some hysteresis, and the lower the circulating water temperature, the less hysteresis.
OK, that's the theory, but in practice what difference does the temperature of circulating water make? I see it will impact on the DHW, the boiler will heat the water, and if this is hotter to the immersion heater setting, then it will not use any solar to heat water on a sunny day, but winter we do not get many days when electric is exported, so not many days when the immersion would switch on, but it would switch on enough times to remove the risk of legionnaires.
So should the temperature dial be altered spring/autumn to winter?
My own control install, is entirely automatically compensated, dependent on the outdoor, indoor temperature, and the measured actual, verus desired temperature - heating CH versus HW separately, at different temperatures. I suspect it saves me quite a lot, but the big advantage is comfort. the cooler CH temperatures, longer, slower burns, reduced swings in room temperatures, much less noise from pipes, and radiators heating and cooling.
With an on/off boiler, that is not an option, boiler need to option to modulate to do that. I did an experiment earlier, I put the heating up 0.5°C 1771862842001.pngand watched to see how long it took, clearly the thermostat turned the boiler off before the flame icon went out, as it showed still heating, but the inlet to the radiator was cold, Wiser does claim to work out things like this, and it clearly does. It gets outside temperature from the internet, and it has transformed my heating. I must give it full marks.
But the circulating water temperature is a manual dial.
The heating has a few minutes ago jumped from 21°C to 22°C and radiator is fully hot, but when I went from 20.5°C to 21°C for that test even after an hour the bottom of radiator was not hot, so Wiser must have been using some mark/space switching to stop it over shooting.
The thermostat has 4 options on boiler heat source type, and then option OpenTherm or on/off, so it is set for an oil boiler, on/off control, the Useless Nest Gen 3 also wanted to know oil or gas, and I have really no idea as to how it uses the info, but Nest would over shoot, so I set it to raise at 0.5°C at a time, but Wiser does not over shoot.
But to put is simple, I have not got a clue as to where to set the boilers dial.
I'm guessing that there will be an optimum flow temperature for maximum efficiency? - taking into account the building thermal characteristics and outside and inside temperature. Too high heats rooms faster but will use more energy?
Not sure how weather compensation achieves this any differently to opentherm, or load compensation, which is using internal temperature only though.
If the system knows the outdoor temperature, it gives it a basis to work out the likely heat loss. The heat loss, allows it to work out how much energy it needs to use to maintain the temperature. It has advance warning, of the likely demand.
