- Joined
- 7 Jul 2015
- Messages
- 44
- Reaction score
- 4
- Country
Hi
I have an Grant oil boiler. Gravity fed HW. Single zone C-plan, no actuators, one pump, heating system. Two tanks in loft. immersion on first floor. HIVE hw/ch wireless controlled with receiver next to boiler. The wiring is very simple and all components are in the boiler cupboard in the middle of the house on the ground floor.
We have built an extension at the back of the house to extend the kitchen where we are having wet UFH. Haven't decided which company yet. The manifold will be fitted under the stairs which is accessed from the extension. The extension UFH has 3 zones.
Stage 1 - Replace the radiators in the old kitchen with UFH. this means the input to the UFH is the existing CH zone. Obvs we wont be able to have the UFH on without the house heating on.
Stage 2 - I've added 2 x 22mm pipes through the ceiling to the top of the boiler cupboard and down the walls of the extension which go under the stairs. At some stage in the future these pipes will be connected to the boiler in a 2 x S-type ch system. Unless we change boiler the HW will still be gravity fed I believe. To connect these pipes it's landing carpet up, floor boards up, holes through ceiling, and pipe work in boiler cupboard. Hoping i can leave this for a while.
Sorry if that was too detailed but my question is, what electrics do i need running from the boiler cupboard to the UFH manifold? I have a 13a supply fitted under the stairs. I need a floor probe for vinyl, so i can't use HIVE, which is a shame.
With the stage one set up could I have the UFH pump running whenever the house CH is on? If the house is at temp then the UFH pump is still running but wont cause any issues?
With stage 2 I need a 3 core and E cable as otherwise I wouldn't have control of the S-type UFH actuator to fire the boiler?
