internal or external boiler?
20 Jan 2013
Dyfed
Have previously had an exterior boiler - inherited when buying another place - which after about 24 months I substituted for an interior one. No hard reason for that, just that it had reached end of life and I preferred to put the new one inside.
Now, having bought another property (lots to do) I am thinking about a replacement boiler (existing one is about 30 years old) and going external in a boiler house.
Has anyone here any argument for or against?
Yes, oil boiler - live in a rather rural area, no gas (other than in a can) and you could not pay me enough to have ASHP
I would put an oil fired boiler in its own boiler house if it was me.
A nicely built timber one with cavity and insulation so it’s properly weather tight and won’t suffer condensation.
In regards to ASHP, have a look at Urban plumber and heat geeks on YouTube…..it’s worth a look.
The problem with the U.K. is we very often don’t design gas boiler systems very well, so with that legacy, it’s no surprise we aren’t good with ASHP.
I don’t know if the new modulating oil fired boilers are any good, but if they are maybe things like variable flow temps etc might be possible or different temps for hot water, heating and even underfloor heating.
It might be worth looking at your system design and considering future proofing now
You can buy a external one in a heat Pac, I have a 19 year old 20kw Firebird SE boiler as good as the day I bought it.
We currently fit 2 to 3 oil boilers a week (Grant registered installer's)
The majority are now external can't understand why anyone would want a internal oil boiler if there is room for a external.
One thing you have to allow for is that external boilers have a built-in frost thermostat so a automatic bypass is a must.
I have unfortunately inherited a gas boiler in an un-insulated garage and the wretched thing fires up over & over again during the night and sometimes in the day due to it's frost stat wasting lot's of gas in the process! If it ever wears out I will replace it with an internal one for that reason and if I was looking for another house I wouldn't touch one with an external boiler.
P.S. I had an internal oil boiler in the kitchen in the last house, no problems so I don't know what all the fuss is about!
Reviving this thread because I’m curious what you ended up choosing for the new place. For a second property, I usually look at access for servicing, noise, and how much insulation the outbuilding has if I’m thinking about an external unit. Did you notice any running cost difference after moving the boiler indoors at your first place?
I had a similar headache last winter and ended up sorting it through https://boilers2go.co.uk/ because I could compare models quickly and book the install without faffing around. The Gas Safe engineers were solid, and the flexible finance made the hit a bit easier. The long warranties also gave me some peace of mind after the old boiler kept acting up.
Avoid them at all costs.
