Hive duel channel
4 Mar 2026
Please can some one help ive fitted hive duel channel to a y plan system heating works as it should the hot water wont work with out the heating switched on the 3 port valve wont switch over to enable hot water i know every thing is wired correct at the reciver my promlem is at the wiring centre there was no room stat ever fitted to the system im not shure if i need a jumper cable fitted in the wiring centre to enable the hot water to switch on without the heating hear is a picture of the wiring centre please can some one help
Yes it gets fired up from the motorised valve but if i just want hot water without the radiators on its not telling the 3 port valve to close and allow hot water only
Sorry ive explaned it wrong was meant to say the valve works as soon as you switch the ch on but wont allow hot water only if i select hot water only the light on the hive reciver turns on for the hot water but not sending a hot water command to the 3 port valve
Ive no photos just copyied the wiring from my dan floss prog wiring diagram to the corasponding terminals on my hive wiring diagram live nutral earth termnal 3 hot water on t4 Heating on
As @ericmark mentions - a Y plan system doesn't send anything to the 3 port valve when there's a HW only demand. The Live comes from the programmer HW on > that runs through the cylinder stat > if that is calling for heat the stat then passes that Live on through to the wiring centre and then out to the boiler's SL to turn it on.
The 3 port valve, when there's no call for CH, has no power to it and the internal spring holds the valve to HW only (B Port).
If it's not doing that then unfortunately the wiring's wrong.
