By change I came across this Channel 4+ documentary by Guy Martin. It starts by as with most talking about insulation and draft proofing, then it starts to get into the nitty-gritty of humidity. We are told the ideal relative humidity (RH) for a home is generally recommended to be between 30% and 50%, and to heat the home keeping below the 50% limit, we need to either except some drafts, or fit heat recovery unit of some type, or use a dehumidifier.
I tried fitting an extractor fan with a humidity switch in my fathers bedroom when we fitted a step in shower in the room, it did not want to switch off. Once the sensor gets wet, it is not sensing the air any more, but drying out, and once the relative humidity hits around 85% we start to get water forming on the sensor, so the sensors basic stop working at 85%.
Getting the house more humid is easy, add some plants, but making it less humid is hard.
