- Joined
- 17 Mar 2022
- Messages
- 90
- Reaction score
- 12
- Country
I'm having to work with both imperial and metric pipes and fittings in an old house. Earlier today I put a 15mm pipe with with olive into an imperial fitting, tightened it up, only to have it burst out when I turned the water back on. I had thought -- wrongly!! -- that because the imperial pipes will go ok into a 15mm fitting with a 15mm olive, the same would work here.
Anyway I cleaned up and found an offcut of the old pipe that had still had the old olive on. I put it back in and spliced it into the pipe run with a 15mm coupler, since I know that works. When I turned the water back on, everything held. My question is: if it doesn't fail straight away, does that mean it's going to be ok? It's not dripping or weeping, and all the other fittings are fine. But after seeing the other pipe shoot out I'm feeling pretty tense, and would like to feel certain that it's not going to fail in the middle of the night or something.
I know that eg soldering would probably be better, but there are access issues that make that very difficult. Thanks in advance for any help / reassurance --
