Long shot.
Have you got a red or a yellow rawl plug, if you have, that'll sort it.
I have got a feeling that the answer is no.Long shot.
Pulling Teeth springs to mind!I have got a feeling that the answer is no.
and they did, in fact, give me one. the cocktail stick idea is genius and im going to attempt that nextI think the OP was hoping for some magic solution to be created by the internet that wouldn't involve any significant effort......![]()
Didn't think we'd see you backand they did, in fact, give me one. the cocktail stick idea is genius and im going to attempt that next
i do, the problem is that i cant fit such things through the hinge holesLong shot.
oh i got distracted yesterday waiting all day for the wood filler to dry to see if that would help, but i cant stay away from this place for long! =)Didn't think we'd see you back
Matchsticks work better in my experience but cocktail sticks will work, and i squirt some PVA into the hole before filling it with matchsticks/cocktail sticks.
Wood filler won't work as it doesn't have any strength. It might work in the short term, but the screws would quickly come loose again.oh i got distracted yesterday waiting all day for the wood filler to dry to see if that would help, but i cant stay away from this place for long! =)
If the top hinge is properly attached then just open the door to 90 degrees and wedge something under the door to support the weight. You could then remove the screws that you're having the problem with and fold back the hinge to access the holes that are too large.i do, the problem is that i cant fit such things through the hinge holes
i really don't want to take the door down and start over. Honestly, i am afraid of it.
This door weighs 40kg, i physically do not have the strength to do this capably, i'm working alone and really struggling, it took hours to get it where it is the first time
i will if i have to, but there are other options to explore first
~absolute worst case, if i have to start over, maybe i could just cut out that chunk of the frame, replace it with a fresh block of wood and use wood filler to join it to the surrounding parts, would that be a bad idea?
glue now aquired at considerable gouging after a trip to the corner shopDidn't think we'd see you back
