Installing concrete floor
18 Jan 2026
Hello, I’ve just started digging out a concrete floor to replace a worn out slab and was hoping to get a few pointers regarding the install.
30m2 floor area and I’ve planned;
1, Compact the sub-soil 2. 100mm MOT compacted 3. Sand blind and lightly compact 4. 1200 DPM 5. 100mm Eco-Therm insulation and 19mm perimeter insulation
6. 100MM C25 concrete to around Finished floor level.
Access to property is restricted and wheel barrow can’t get through FRont or back door. I’ve spoken to a local concrete company who can supply, pump and level the slab for around £1500.
My main questions are
1. I’ve read that you won’t be able to place laminate flooring or carpet directly on the slab as it’ll be too rough, can anyone suggest the easiest way to get the slab smooth enough?
2. I am planning to support the stairs with some sort of brick or wood pad placed between the stringer ends and the insulation. Can I just leave this in situ and embed it in the slab once poured ?
Any help would be appreciated.
I'm not a builder so take this with a pinch of salt.
Concrete floor is an easy one. Put some self leveling compound down after the pour. Very diy friendly.
Re the stairs, I'm planning to do the same. Bit ill use a concrete terma block. Easy the but to size and lay.
Have you considered running all your power an water supply in Central guttering tj make it easy to change/ run bee cable in the future?
I was hoping that you could simply pour a thin layer of levelling compound on the floor to just cover the surface stones, but I wasn't sure it would actually stick to the new floor and not crumble when walked on. Mind you, it would need an awful lot to cover a 30m2 area.
I can get away with surface mounting my pipe work but it would be neater buried, it's something I need to think about. The gas pipe needs to be encased in the actual concrete as far as I'm aware.
My main aim was to get away from having to have someone out to do a separate screed, hence, having concrete on top of the slab. It's a shame you can't screed it in sections like they do when plastering a wall,using battens to screed off
If you prime it, it will stick. This is fairly common and what the builder did on my extension.
The other option, which might be harder and more expensive is to have the concrete polished. But I'd only do this if you were planning to display the concrete floor.
Burried would be better. More importantly, what are you going to do in 5 years if you want to add another socket or radiator? This is what has put me off making the switch.
A option someone mentioned to me, but sounded a bit of a bodge, was to put the slab over the dpm, a layer of sand on top and bed the insulation on the sand,then caber deck the floor?
This is the first house I've had with a concrete floor, it's proving to be a real headache, so much easier with a suspended floor
As long as the main ground bearing slab is done right, then you can make up whatever on top of it. The dpm would need to fully enclose the insulation and floating floor though so might end up more hassle and it’s not normally done like that.
When i did mine, which was about the same size as yours, I made it so when the slab was poured it could be tamped dead level against 2x2 formers, which gets it fairly close, then a few hours later when it could just take my weight stood on a bit of board, went round the entire thing and troweled the hell out of it with my plastering towel, which was hard work, but resulted in a really nice smooth finish, not a typical dusty aggregate concrete finish. Did it again since on a garage. It’s a bit of a ball ache but works for me.
Still had to do the odd patch of SLC to get it bang on (SR1 3mm tolerance?) for large porcelain tiles but that was dead easy and was only a couple of bags.
You'd normally screed a slab and a good screeder will produce a finish that needs no levelling.
If you don't want to do that then a powerfloat used properly will give you a suitable finish
Agree on the screed, but having done both over the years the slab finishing method I described above I’d say is DIY’able, a decent S&C (or pumped) screed much less so!
Here’s a previous thread about this:
I think others have asked the same question; search the forum.
In terms of compacting the sub soil and MOT, I'm concerned about using a whacker plate in and around the house walls, talking to neighbours, I think these properties have had issues in the past. The sub soil looks really loose, you can dig it with your hands easily.
I've never used a whacker plate before, so I may be overthinking it, but would using a garden roller be effective and gentler ?
A roller won't really cut it, use a hand tamper in sensitive areas. In the past I've got by with a 4" fence post.
