Can't be because that (imperial equivalent) is what you would have needed with a 30A BS3036 fuse.Too small for a 6mm?
Indeed, I reckon the original intention was that the lug on the "fuseholder" base was to cause it not to seat down properly to deter fitting of it, of course it was not uncommon for someone to saw/grind it off ore even just crudly cut it off with a pair of sidies!View attachment 410241I would say the two contacts look very different. I assume also different isolator, but with the rating written on the back View attachment 410242 not easy to see, back when these were used 60 amps was the normal supply.
I seem to recall it was not wise to replace the breaker without the supplied base as the base would dictate how much of the blades went into the bus bar tabs
Yes indeed the ubiquitous Wylex 404 and its big brother the 604 , we were brought up on rewireable fuses and later on the MCBs (push buttons for a long time but they had the habit of sticking so later on replaced by flick switch) .The presence of a 60A main switch is a recognition point.
if it has not fallen off or worn away, there will be a label under the switch.
In the heyday of Wylex standard, many small homes only had a 4-way CU
Lights 5A
Sockets 30A
Immersion 15A
Cooker 30A
Maybe. I knew nothing about these 'notch things' until it was mentioned here.B and Q used to sell clones of them breakers under a different brand, i thought the notch thing was for the green 45a rather than the orange 40a
@JohnW2
I never had anything to do with the 'original' push-button ones. I illustrated ones I'd found of both the 'wide' and 'narrower' versions. Both were elastic-banded onto bases which were identical (hence 'wide'), so I presume that's how they had been installed (correctly or not!).Older versions were push button types using the fat base, then they changed to the toggle type like you have and stayed with the fat base i believe they were the old Bs 3871, they later changed again to the slimmer mcb with the slimmer base and Bs.60891
The 'narrower' and 'wide' devices I found had (correctly or otherwise) slightly different (but virtually identical) bases, but with no material difference as regards how much of the blades 'protruded'.I seem to recall it was not wise to replace the breaker without the supplied base as the base would dictate how much of the blades went into the bus bar tabs
I knew they didn't fit but ironically I'd never looked to see how/why.Maybe. I knew nothing about these 'notch things' until it was mentioned here.
What about Wylex boards without a main switch?The presence of a 60A main switch is a recognition point.
Goodness - I've never seen one of them!What about Wylex boards without a main switch?![]()
That's the only one I've ever seen in the 23 years I've worked as an electrician. (I've seen the little 2 way 'extenso' extension boards that of course don't have a main switch but never a full sized one) It's not modified, there was no hole in the cover for a switch.Goodness - I've never seen one of them!
Indeed and the origin of the format, I haven't seen one for a long time now.
