I have a small two bedroom flat that I let out. Circa 1970s low rise block of flats (above average quality for the time).
Current EPC rating D (I think) could be E. But some improvements have been made since then.
It comprises of a small bathroom, one small long box bedroom, and a main bedroom and one large living area and kitchen.
Current Set-up:
All electric E7:
Original fortic cylinder (terrible hot water pressure) with immersion heater.
3 large 2kw storage heaters. One in main living area and two others in the bedrooms.
Storage heaters are the basic manual type but were installed in 2007, so not ancient.
It was suggested that I make some improvements to the hot water pressure, so I was considering replacing the fortic to a unvented cylinder.
It was also suggested at a future point I consider upgrading to LOT20 HHR storage heaters to get a better EPC.
But, there is an available gas supply to the property that is just unconnected at the moment.
So I just wanted to bounce some thoughts:
Option 1 (current plan): Just replace the ageing fortic cylinder to direct unvented and get much better water pressure.
Stick with current manual storage heaters as while they may not get a better EPC value, the actual energy use is probably no better than LOT20.
Pro:This seems to be the best cheap upgrade to a set-up that is largely maintenance free.
Con: Clumsy system, not user-friendly, poor EPC rating
Cost £1200ish
Option 2: In addition to the tank, upgrade the storage heaters to LOT20 HHR type to get better EPC rating?
Cost £2000ish - Pro -Option to get better EPC rating and creature comforts for tenant
Con - Cost of upgrading one system for a similar system without much benefit other than a better EPC rating
Option 3: Full switch to gas combi boiler and central heating.
Pro: Ease of use, cheaper bills, lower EPC value. More attractive for people.
Con: Cost of install (£5000? ish), ugly pipework routing (concrete floors), annual servicing and maintenance, potential for gas to be penalised as a fuel source in the future vs more efficient electric setups?
Current Set-up:
All electric E7:
Cost £1200ish
