Blast Off Is Imminent
2 Feb 2011
Bristol
Elon Musk is heading for the stars, what will be the affect on CO2 levels?
They are currently 0.04% that's 4 parts in 10,000 and we're all going to die apparently according to the little gremlin with pig tails, if CO2 levels drop to 0.02% ALL PLANT LIFE WILL DIE WHICH DOESN'T BODE WELL FOR THE HUMAN RACE..
Back to ARTEMIS II, they are off
Artemis is a Boeing rocket not SpaceX. Musk doesn't have a look in. As for the ELC climate change denial you need to do more digging.
I didn't realise that Elon wasn't involved, regards the make up of air I'm a BSAC diver , I need to know what is going into my air tank, take oxygen, its poisonous at 2 bar, as its only 20% of air it's not poisonous until depths in excess of 90m
Why
do they pump CO2 into greenhouses?
In your own time ...
Who remembers the 70s
Global Warming
We're all going to die
Global Cooling
Ice Caps Melting
River Thames freezing over
Acid Rain
Ozone layer Layer depletion
Now we have Climate Change to cover all eventuallies,
Al Gore was it started the ball rolling, he's made millions of dollars and now Mad Ed Milliband has jumped on the band wagon..
Why
See, with your level of attention to detail I don't think you're really someone id trust.
Case in point: pure oxygen is toxic at all pressures. However as the pressure increases the rate at which it affects you also increases. What might take days at 1 bar takes four hours at 1.3 bar.
That's why technical divers can use pure O2 in some cases deeper than 6m and why you have to monitor your pressure exposure time. Or you would if anyone actually dived recreationally on pure O2.
Technical divers do not use pure O2 deeper than 6 meters, it would kill them. Technical divers use pure 02 during decrompression to remove nitrogen quicker from their blood, the nitrogen comes out of sollution and forms bubbles in the blood stream if the diver surfaces to quickly, known as decrompression sickness or commonly known as the bends, an 02 tank is hung at around 6 metres and is used briefly in a controlled way by the use of timers. Stop talking nonsense on subjects you know nothing about.
Air is safe to 90 metres where the pressure is 10bar, that's where the 20% of oxygen reaches 2 bar, at sea level the pressure is 1 bar, oxygen is pressure is 0.2 bar in the lungs , 10metre equals 2 bar, 1 bar every 10 metres, my deepest dive was 40 metres , that was 5 bar and the air in your tank doesn't last long as the pressure in your lungs is 6 bar
Global Warming
Global Cooling
Ice Caps Melting
Acid Rain
Wrong thread, you need to get yourself over here https://www.diynot.com/diy/threads/climate-change.646767/
Everything you have just said has all been gone over before and more too.
