- Joined
- 7 Sep 2022
- Messages
- 4,931
- Reaction score
- 1,437
- Country
I’ll make a note to remind you
'Oh well, I'll just hope that the combination of a higher price than that mentioned by the OP & the fact that the rad. wasn't sourced through the 'bay might mean I've ended up with an item from the premium range.Mahle-Behr is all over ebay. For the E46, there is the cheaper standard one and a premium-line one. I am guessing the materials are thicker on the premium and more able to resist bumps. Since it isn't OEM, a Nissen one might be no worse. Nissen has a single model, presumably matching the premium-line one, but has discounted offers.
I have a Nissen radiator on my old Alfa. It's nowhere near as good as the original. I'd avoid them in the future.Mahle-Behr is all over ebay. For the E46, there is the cheaper standard one and a premium-line one. I am guessing the materials are thicker on the premium and more able to resist bumps. Since it isn't OEM, a Nissen one might be no worse. Nissen has a single model, presumably matching the premium-line one, but has discounted offers.
I've had a Nissens on my old Range Rover classic for over 4 years without issues, but that's only about 7K miles ago so perhaps it's storing up surprises for me.I have a Nissen radiator on my old Alfa. It's nowhere near as good as the original. I'd avoid them in the future.
Weight isn't necessarily an advantage for a radiator - often the opposite. Thinner-walled tubes dissipate heat faster.
Thermostats can be tricky blighters as well, back in January my old 5 series overheated about 3 miles from home, following a cold start. Recovered to our local garage.No, the cooling was noticeably worse on my Alfa from the moment I turned the key. (Well, OK, the moment the thermostat opened, after the moment I turned the key...)!It just doesn't cool as well as the old leaking one did. That was an "old skool" copper matrix with brass header tanks, soldered together. The Nissens one is the modern plastic header tanks and aluminium matrix. I think it has just been designed down to a cost. It has one less row of tubes than the original one.
Thermo. suspected, but when tested by immersion in hot water it operated fine.
Replaced as a matter of course, no further problems over the past 1300m.
Annoying but at safe, at least you won't cook the engine. Mine got very hot but I seem to have caught it in time, boiling can be fatal with a BMW.I tend to have the opposite problem - all mine always seem to fail open!
I always glance at the temp. gauge fairly often as the stupid thing is 'buffered' & doesn't move past normal until things are getting critical .. it was the warning gong that alerted me, right in the midst of 2 lanes of peak period traffic !
I concur, BM's excuse is that they don't want owners to be alarmed by slight movements of the needle driven by 'normal' fluctuations' in coolant temperture.So whereas I might have noticed it reading "a little hot" on some runs, the gauge stayed resolutely in the centre and then all of a sudden, "BANG"! Right into the red!What's the point of having a gauge and then adding software to make it behave like a warning light?
That tells me you have something else that isn't working. My car ran fine with 4 litres of coolant leaked out on the road after collision. Although it was cold weather at the time. I don't need better cooling. I need thicker materials to play bumper cars. Nissens would work out better for me: more materials for lower price.No, the cooling was noticeably worse on my Alfa from the moment I turned the key. (Well, OK, the moment the thermostat opened, after the moment I turned the key...)!It just doesn't cool as well as the old leaking one did. That was an "old skool" copper matrix with brass header tanks, soldered together. The Nissens one is the modern plastic header tanks and aluminium matrix. I think it has just been designed down to a cost. It has one less row of tubes than the original one.
On the subject of corrections, this is what I think you meantIf what you change on a vehicle, does not materially affect the safety, handling, braking, or speed, then the insurco will have no interest at all.
One of my pet hatesComprises means “consists of”; do not follow “comprises” with “of”
No, nothing else changed. Took out leaky old radiator, fitted new one, refilled and bled system, job done. It's just a crap radiator. I have since found and bought an original, and I might replace the Nissen one this summer if the weather gets hot - in which case, I'll happily post you the old Nissen one to tie to your bumper and use as a fender for playing bumper cars, if you like!That tells me you have something else that isn't working. My car ran fine with 4 litres of coolant leaked out on the road after collision. Although it was cold weather at the time. I don't need better cooling. I need thicker materials to play bumper cars. Nissens would work out better for me: more materials for lower price.
