Whatever you are more comfortable with, could just be washers.Thanks, is it easier/ quicker to get the float valve repair kits or replace the float valves ?
Well your middle pic shows the water level right up to the overflow, so if the water's not draining out through that where has it been going?I’ve shoved a hosepipe the length of the overflow pipe but it doesn’t seem to be draining out
Hi John, thanks for your message, I’m trying to limit the amount of times I go in the loft so I turned the stop tap inside the house off, the point was to see if the water level in the tank was going down so I thought it would have the same effect.
