- Joined
- 7 Sep 2022
- Messages
- 4,924
- Reaction score
- 1,430
- Country
And what do you think will happen?No - it's plasticised.
If the plasticiser is 'leeched out', the material can become brittle.And what do you think will happen?
I have no idea, but I'm not at all sure "small molecules like O2" have got much/anything to do with it. I didn't think that the potential issue was related to 'impervious coatings' but, rather, to substances that could result in loss of plasticiser - but, as I've said, I don't know.Indeed.. a) so coating a PVC cable with something fairly impervious to small molecules like O2 will make it more likely that larger molecules like C24H38O4 will be encouraged to leach out, embrittling the cable?
That's surely fairly obvious, isn't it? If the PVC of cables loses its plasticiser, it may crack if flexed etc.... and .... b) so what?
Indeed..
and
b) so what?
Quite so. I, for one, have 'seen it', and it's quite 'interesting', even though I don't fully understand the chemistry!Have you ever seen what happens to PVC cables in contact with expanded polystyrene?
Well, he’s decided to move them, paint, then refit so it’s decided..Surely the op could wipe silicone grease (or similar) on the cable?
I wondered how long it would take you to invoke that. Go do some more research on it is before leaning on it as your primary argument for an unrelated substance that doesn’t contain the material at hand.Have you ever seen what happens to PVC cables in contact with expanded polystyrene?
I imagine his point was that contact with some 'substances' (of whatever nature) can harm plasticised PVC, rather than that the 'coating' (or not) of the cable with something 'impervious', per se, was a relevant issue?I wondered how long it would take you to invoke that. Go do some more research on it is before leaning on it as your primary argument for an unrelated substance that doesn’t contain the material at hand. ... Your argument is a non sequitur
You seem to be consistently blind to and/or intolerant of views other than your own, and I'm not sure that your sarcastic style does anything to make your comments be taken seriously. You also seem fairly selective about whom you choose to criticise.“Don’t use things; some other things, some where, can cause some things to happen to them, so perhaps other other things else elsewhere can also cause things to happen” .... Mmm. Definitely a useful mantra
Indeed..
and
b) so what?
Indeed, and I suspect that he probably believes that his attempts actually do result in his 'scoring points', whereas the truth may well be that they actually 'lose him points'!Yep, he does frequently try to score points for himself.
