Having solved the problem caused by my inverter, I have a follow up question.
I've been looking for a double pole switch that allows me to manually switch between the inverter output and the normal mains circuit feeding a circuit containing lighting and charging points.
It's a simple workshop setup running from a couple of solar panels, but given the uncertainty of charging and battery capacity I would like to be able to use either power source but can't seem to find a suitable switch.
Cheers
Cheers
