- Joined
- 7 May 2026
- Messages
- 12
- Reaction score
- 0
- Country
then that shows you how very little you know!No, it really isn't.
you mean they are AI imagesFrom the dark web. But it's so dark, you'll need aveatry's powerful torch that can light up the night sky, to see it.
Because of the chemtrails and Ellon Musk 5G satalights, there really is very little to be seen in the sky at nightNo one paying attention to the skies today -- look up they are at it again
well where is the Artical?You are describing aircraft con-trails.
There is zero evidence to support anything of the contrary. In fact, an article recently posted up on here, explains in detail, how ridiculous the suggestion that commercial aircraft spray chem-trails actually is. You would need to be extremely stoopid to believe in the notion, too.
Different atmospheric conditions.Yesterday. the sky was full of con(chem)trails. Theories are bandied about, whether they are just water vapour or chemical seeding for some purpose. Today, the sky is clear. weather is near as damn it the same as yesterday , temperature, wind and barometric pressure wise, and I can see and hear the aeroplanes, so why no trails?
Did you read what I wrote?Different atmospheric conditions.
Next person to call them chemtrails gets a slap.
Which one?Did you read what I wrote?
The weather at ground level is irrelevant. Its the conditions at flight level that matter, and those can vary a lot without any impact on the ground.Did you read what I wrote?
Surely atmospheric pressure at ground level being the same on 2 days will mean it is going to be the same (although lower)at a higher altitude the same 2 days , the same with temperature, wouldn't the difference between temp. at ground level and 40,000ft remain constant, and wind speed to a lesser extent?The weather at ground level is irrelevant. Its the conditions at flight level that matter, and those can vary a lot without any impact on the ground.
The debunkers primary weapon is atmospheric conditions that explain why contrails one day and chemtrails on another day. Or even morning Vs lunchtime.Surely atmospheric pressure at ground level being the same on 2 days will mean it is going to be the same (although lower)at a higher altitude the same 2 days , the same with temperature, wouldn't the difference between temp. at ground level and 40,000ft remain constant, and wind speed to a lesser extent?
Nope, they all can vary significantly and don't affect us on the ground. There are multiple layers of air that isolate changes from each other.Surely atmospheric pressure at ground level being the same on 2 days will mean it is going to be the same (although lower)at a higher altitude the same 2 days , the same with temperature, wouldn't the difference between temp. at ground level and 40,000ft remain constant, and wind speed to a lesser extent?
... Except there are contrails at night and planes don't cross the same small patch at the same altitude because they're not allowed to.The debunkers primary weapon is atmospheric conditions that explain why contrails one day and chemtrails on another day. Or even morning Vs lunchtime.
But that doesn't explain the absence of chemtrails at night or when paying attention and observing same planes same height cross the same small patch just mins apart one cons and one chems
Nothing can explain why contrail one day and chemtrails the next. Want to know why? Because chemtrails don't exist. The only place they exist is in the heads of consiracy theory idiots.The debunkers primary weapon is atmospheric conditions that explain why contrails one day and chemtrails on another day.
It’s a decent start. And the fact that there are concise logical reasoned articles out there explaining why chem trails are utter nonsense. Yet you CHOSE to believe in them.The debunkers primary weapon is atmospheric conditions
Where did you get this information? I looked online, the difference will stay constant. Can you give me a link where it says the difference between atmospheric pressure and temperatures at similar heights will differ ?Nope, they all can vary significantly and don't affect us on the ground. There are multiple layers of air that isolate changes from each other.
