Shiplap Cladding Gaps - help !
15 Jan 2020
So I was very proud of my new shed - for about a week
And then I noticed that gaps were opening up between the shiplap presumably as the wood dried out - my bad for not leaving the wood long enough to dry out before fitting
I installed it with 1.5mm gap but some of the gaps are now 6mm and I'm guessing these will leak (and may get bigger)
I'm pretty much resigned to moving the boards around and closing the gaps up - luckily I screwed the boards on so easy to remove - on 3 sides at least
So couple of questions
1) Shall I leave it a few more weeks so it dries further - then refit with a 2mm gap maybe - or do I need to wait longer ?
2) Is it worth putting some breathable waterproof membrane on under the cladding ? Its "only" a shed but I do want it waterproof - any suggestions for what to use ?
Funny the old shed I replaced was a cheapo kit build and that never leaked - until the felt on the roof rotted
If you want waterproof cladding you need a breathable membrane on the outside face of the studs, then vertical battens, then the cladding. Any old cheap breather membrane off ebay will do for a shed.
Thanks - I can't get battens on unfortunately due to the roof overhang
Would cladding directly on the membrane work ?
A breathable membrane relies on an air gap for two reasons, firstly to allow any moisture that does move through the membrane to be able to evaporate once it reaches the outside air and more importantly (for you) to allow any rain that penetrates the cladding to be able to escape down the cavity, rather than just sitting there. So if you have no cavity the rain cannot escape and may well just soak the membrane and lead to moisture/damp internally. Even say a 1/4" thick batten would be better than no batten, as to whether it would be effective long term is anyones guess.
Post a pic of the roof overhang detail you believe to be problematic for adding battens and maybe we can suggest something.
Look at the last picture, f all overhang, this is his second mistake. I'd be extending that even if the shiplap was ok.
my thoughts
you need to know the coverage off a dry plank then add 1,5 to 2mm for expansion
for example my 5"txg shiplap was 109mm dry coverage [shoulder to shoulder] so aimed for 111mm and iff the planks where a bit more than 111 then get as tight as possible or iff less space them out
