Removing kitchen tap handle without visible grub screw
6 Dec 2015
Just want to sanity check I’m not missing something obvious before I use serious force on this tap handle. Only screw I can see releases the spout as you can see in the photo. No grub screw holes or caps to take off. There is a tiny hole where there is a red and blue dot either side, I’m pretty sure that is just to say which is which tap as it’s too small for an Allen key.
I’ve already taken the hammer to this, might have moved a few mm but it’s not budging. Just have to keep going?
You can see the red dot at the bottom of the handle in the 2nd photo.
Not much bigger than that tool you need to use to get SIM card out of an iPhone!
I always use dynamite in these situations...
Have you tried pushing a pin into the hole? It just might, perhaps, possibly, maybe release some catch to allow the handle to pull off.
I’ve a similar tap and the the grub screw hole is on the very bottom of the tap handle with th tap in the off position , a bit of an awkward squeeze between the handle and the worktop
There’s definitely nothing there mate, I fully expected there to be but I’ve cleared away any limescale and there is no hole. Bit strange
That indicates that it’s hot water. I would say if there’s no screw that it pulls off.
