Waste pipe leaking
20 May 2026
Hello everyone,
I just wanted to get any plumbers opinions on this work that I have had done... (as a layperson, it even looks shocking to me).
I have had a downstairs bathroom fitted, with the waste pipe of the new bathroom (the grey pipe) and what looks like drilled and fitted into the main waste pipe of the upstairs toilet (forgive my lack of knowledge on any technical terms/names). Basically, I heard dripping from within the wall, so I've hacked out a hole (which looks like I've done it with a knife and fork), and sure enough there's a leak whenever the toilet is flushed. Can you please tell me if the work that's been carried out here is 1) the done thing when carrying out a job like this? And 2) Just how bad does it look? Thanks in advance.
Harry
That looks like it’s been bodged onto a cast iron soil pipe and then bodged even further with the bath waste and loads of silicone. Were you feeding and tending to the horse whilst the work was being done?
Hi, what pipe is that as it looks very small.
Andy
Andy,
No idea mate. It's the waste pipe coming from the new downstairs toilet. My initial thoughts were the same reference size, so I made it a 'no poo loo'.
Hi mate. Correct, it's cast iron.
Do you think it will be a big job to rectify?
I cant say, Harry.
Send a few more detailed pictures and we might be able to give better advice
That sounds about all correct... apart from the horses.
What do you suggest as a fix?
It depends, if it’s not too far down to the drain connection, then maybe upgrade to pvc to that point and use a cast to pvc adapter, eg Fernco. If not a viable option, then maybe x2 fernco, a bossed pipe or piece of pipe and strap boss.
