I watched a Jonathan Tracey YouTube called Is Plug-In Solar LEGAL in the UK? He links to
Is Plug-In Solar Legal in the UK? The Complete 2026 Guide which says "Quick answer
Yes, plug-in solar is legal in the UK since 24 March 2026."
But then continues "The BSI product standard that certifies kits for DIY self-connection is expected summer 2026. Until then, the fully compliant route is to use a qualified electrician."!
It does seem it is legal, but does not comply with regulations, which seems to be splitting hairs, as that has always been the case, there was no real change to any law on the 24th of March 2026.
If using a FCU it is not plug in solar, simple, can you use plug in solar and comply with the regulations, the answer has to be yes, but not using a BS1363 socket, you would need to use an EV charging socket.
A reference to "The wiring regulations (BS 7671 Amendment 4) are live." seems daft, as it was BS 1363 which did not permit it, so that needs to be re-written before we can use a 13 amp plug.
OK, then why bother writing website?
So What you CANNOT do yet - Skip DNO notification — it's a legal requirement regardless. - Plug a kit into a wall socket yourself and be fully compliant.
So why say "Quick answer Yes, plug-in solar is legal in the UK since 24 March 2026."?
Either you can plug it in and be fully compliant or you can't, so quick answer it seems is No.
So why bother making the video? Every report I see is by someone who already has completed a G99 or G98 and can get paid for export, so for the people that plug in solar is aimed at, the person in rented accommodation who want to be able to move it home to home, the report is useless.
