- Joined
- 27 Jan 2008
- Messages
- 29,351
- Reaction score
- 3,608
- Location
- Country
I have a portable AC which will stop room getting too hot, but once hot, not very good at cooling it again. So at midday (1 pm BST) my living room at 26.6°C so turned the AC on. But really too late, all windows closed, one internal door has a gnome stopping the door fully closing to allow cats in and out, and also allows replacement air for the hot air the AC put up the chimney.
Clearly using more power
but still exporting
so not really worried about the cost to run. But can I get a bigger unit? It says 755 watt load, and cooling 7000 Btu/hour so 2 kW/h which seems to be a standard size for portable units.
It has dropped the temperature ½°C in half an hour, but that is still 26.1°C, if I run a second, the question is where to route the hot air, only have one chimney. And the windows open with side hinges, so the adaptors allow loads of hot air back in.
Can't see a method to improve it, but always worth asking in case.
