Non-bidirectional RCD/RCBO feeding sockets, should they get a code C2 with EICR?
I think it was @JohnW2 who pointed out for the RCD/RCBO to fail it needs to test button to be pressed, while the flow is reversed, but from 10 am to 6 pm today flow was reversed, so there is a reasonable chance of the button being pressed at the wrong time.
I looked at data sheets, non seem to say non-reversible, they only say when it can be reversed, and there are type 'A' which show input and output so the plug in solar website which says
is incorrect. I look at
Round fuse holders, were Siemens not Wylex, and not seen any in the UK, Algeria 1980 loads, as working for a Dutch company, darn dangerous things, as fuse was before the switch, so to change a fuse base it had to be done live.
But it would seem they have translated a German website!
Fair enough. As an engineer, I too am expected to make evidence based judgements, or present evidence to colleagues who have to make a decision.
I'm pleased to hear that - and one might hope that would mean that you would share some of my concerns about things which appear to be minimally 'evidence-based'.
You seem to be applying the same flawed logic that the vendors of these so called safety covers use - that they prevent a risk.
Not at all. In the absence of any hard evidence (or either harm or benefit), I'm just remaining 'open-minded' - I'm certainly not dismissing the claims that they result in some risks (since they undoubtedly do to at least some extent), but nor am I dismissing the possibility that they might also sometimes reduce or prevent risks. I just don't know (and certainly don't know about the balance between the pros and cons), and I would perhaps have expected you to feel the same, given your experience of 'evidence-based' decisions.
I would imagine that would be heard to come by. The main problem is that the general public aren't likely to report anything, and the authorities are only likely to know if it's serious (e.g. someone is hospitalised.) Also, some of the potential harms would not be related to the previous (possibly years previous) use of these items.
Evidence (for either causation or reduction/prevention of harm) would certainly be very difficult to 'come by' - but, if one believed in evidence-based decisions, difficulty in finding evidence is not really, in itself, reason to jump in one direction on the basis of one's theeory-based opinion.
I think you are more generous to the manufacturers than I am. .... I am really sceptical that someone looked at the standard and consciously designed something with larger pins.
You are quite possibly right. However, again I just don't know - so if you want to go with your own opinions rather than anything based on facts, then I suppose that is your prerogative.
As I've recently written, I think we're now seeing similar with SPDs (with maybe AFDs/whatever 'to come'). Some people seem to be totally sold on the idea that they are 'necessary', seemingly almost totally because of theory-based opinions - despite the paucity of any evidence I've managed to find (and I've looked quite hard) that there is actually a significant 'need' for them.
Agreed. Either that, or the requirement should specify what standard it is required to meet - e.g. by referencing an existing standard for flammability.
Sure, the reference to 'non-combustible' is quite ridiculous and those who wrote it should have known better - as you imply, they obviously should have clearly defined what degree of 'flammability' is required.
However, that's not the main problem with that reg - more important is the lack of significant evidence (that I've seen or heard of) that there is/was a significant need for some higher degree of 'fire resistance' of CU enclosures - particularly given that metal CUs etc. do introduce some dangers.
Unfortunately, we seem to be getting ignored as there's been no shortage of people (myself included) who have raised this - yet there's been, IIRC, 2 or 3 new versions where they've failed to fix this f'up that brings BS7671 and BSI into disrepute.
Rumour had it that it was intense pressure/'threats' from LFB that resulted in the appearance of the reg in the first place - so I suppose the same may be resisting any modification to it?
Yes, in relation to a 'full' solar installation, I acknowledged that above ....
.... One imagines that, in Summer, in an installation with very low background loads, there could possibly be net export for 'a few hours' every day, and it's not impossible that someone could press a test button whilst that was the case.
However, as others have said, with these 'plug in solar' systems, I doubt that their output would be adequate to result in much, if any, export for a significant amount of time.
Returning to the actual 'potential problem', none of us have yet thought of any potential issue (with 'unidirectional RCDs) other than that associated with the Test Button, if pressed for a 'significant period of time'. I suppose a couple of simple 'solutions' to that would therefore be (a) to not fit, or disable, the Test Button or (b) utilise a 'momentary action' Test button, whose contacts only remained closed for a modest handful of milliseconds!
So you think there should be an instruction with plug in solar not to press the test button on an RCD/RCBO when the plug in solar is plugged in, and that is enough?
Maybe it is enough, but goes against the grain.
Remember plug in solar is designed for tenants, do you think tenants will worry about pressing a test button anyway?
So you think there should be an instruction with plug in solar not to press the test button on an RCD/RCBO when the plug in solar is plugged in, and that is enough? ... Maybe it is enough, but goes against the grain.
Certainly 'better than nothing', given that at least some users would presumably obey the instruction, but I agree that it would fall short of what one really wants/needs.
What I was suggesting were more ways (in addition to those we've already discussed) of manufacturing RCDs which would not suffer from the 'Test Button Problem' during export.
As you imply, if used by tenants it's probably less likely that they will press the button. However (a) that's no guarantee that some of them wouldn't press the button and (b) there's no guarantee that it will only be used by tenants. However, as I recently wrote, whether such kit will result in export for appreciable periods of time is perhaps a different matter.
However, something has just occurred to me, which I should have thought of before ....
.... do these 'plug-in inverters', like the ones in proper PV installations, shut down immediately if they lose their grid connection? If so, then if the RCD operated because the test button had been pressed, would not the inverter shut down rapidly enough to prevent overheating of the test resistor? If that were the case, would all the interest/excitement about 'bidirectional' RCDs not be unnecessary? Or am I missing something?
