Kitchen Pipe Falling Off
28 May 2026
Hi, the pipe that connects kitchen sink to the outside drain keeps falling off. I can’t push the kitchen pipe out anymore and it seems the water pressure is too much for the elbow. Any suggestions? Thank you.
Cant - It's push fit.
Not enough pipe coming out from the wall, can the pipe from inside be pushed out more and then clip the pipe internally and externally to stop it from moving. That being said it's not the right pipe for outside work, it's push fit and as such is PP plastic that isn't UV stable and it will break down over time. As was suggested, if it can be replaced for solvent weld then all the better
Yes, replace with solvent weld or paint the push fit pipe (when fitted properly).
